Rurrr noise at idle in gear 02 Grand Caravan
Old Oct 26, 2012 | 04:35 PM
2002caravan's Avatar
2002caravan
Default Rurrr noise at idle in gear 02 Grand Caravan
I get a rurrrrr noise when my car is at idle and in gear. If I take it out of gear or raise the rpms slightly it goes away. Some days it's worse than others. When I remove the belt the noise goes away completely. I've replaced the all of the idlers, belt, water pump, tensioner, and alternator. The only belt driven items left are the ac and power steering pump and I don't think it's the compressor. I'd like any advice you may have before replacing the power steering pump.
Old Oct 26, 2012 | 05:20 PM
b1lk1's Avatar
b1lk1
Was it a new or used alternator you installed?
Old Oct 26, 2012 | 05:58 PM
Cougar41's Avatar
Cougar41
Have you used a stethoscope to pinpoint the noise either the standard mechanics type or the shadetree mechanic's length of garden hose?
Old Oct 26, 2012 | 06:37 PM
2002caravan
New OEM with correct pulley.
Old Oct 26, 2012 | 06:45 PM
2002caravan
I did and it sounds like it's coming from the pump but I can't say definitively.
