2003 GC sliding door problem
Old Nov 5, 2012 | 11:04 AM
skrapper's Avatar
skrapper
Default 2003 GC sliding door problem
Hello,
The driver's side sliding door cinch motor will pull the door into position but, then releases it again. This usually happens when it's cold out(under +40f). After repeated tries it will latch securely. Is it just the cold or is there something else causing the problem?
Thanks
Mike
Old Nov 5, 2012 | 11:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
First thing you need to do, is to pull the codes out of the sliding door module and post the codes. There also could be a flash update or door track?
