1993 dodge caravan transmission issues
Old Nov 7, 2012 | 09:20 AM
wolfbone71's Avatar
wolfbone71
Default 1993 dodge caravan transmission issues
My current caravan is having a strange issue. While driving sometimes it will downshift for like 2 seconds then go back into the correct gear. I know this mostly cause my rpms go up briefly. Also the ABS light comes on then goes off. A while back it would downshift when stopped and I couldnt ever get it to go to overdrive. Doesnt do that anymore. Any ideas?
Old Nov 11, 2012 | 01:09 PM
Digger 89L's Avatar
Digger 89L
Sounds like a shift solenoid issue. First step is to do (or have done) and transmission flush and filter / fluid change. This may clean up any clogged or partially clogged solenoids. If you've recently done a filter/fluid change, trying running some SeaFoam TransTune in the transmission fluid (follow instructions on the bottle). I always like to try these "soft" fixes before tearing into things with a wrench.
