EGR valve?
Old Nov 25, 2012 | 03:28 PM
countryboy73's Avatar
countryboy73
Default EGR valve?
I have a 02 caravan se with revving problems. Im thinking its the EGR valve but I can't find it. Can someone help me with this.
Old Nov 25, 2012 | 06:48 PM
grswat's Avatar
grswat
What engine do you have? 2.4 it is bolted to the drivers side of the head. 3.3 and 3.8 are bolted to the front head.
Old Nov 25, 2012 | 11:35 PM
countryboy73
It's the 3.3, is it located over the alternator.
Old Nov 26, 2012 | 07:20 AM
grswat's Avatar
grswat
Yes. There is a metal tube that runs from it to the top of the intake.
Old Nov 26, 2012 | 05:09 PM
countryboy73
Well there ain't one, back to square 1.
Old Nov 26, 2012 | 05:12 PM
countryboy73
Does that year model have a mass air flow sencer.
Old Nov 27, 2012 | 07:32 AM
grswat's Avatar
grswat
Map sensor. Are you getting a check engine light? When you say revving problems is it an erratic idle or won't rev or?
Old Nov 27, 2012 | 09:57 AM
countryboy73
It revs up and down all the time while at an idle. It's not a steady rhythm it varies, it gets fast then slows down. when you put it in gear it idles up high and you have to press the breaks really hard to keep it from moving. While driving it will maintain a steady speed for a minute or so then slowly slow down unless I push on the breaks. At times when at a steady speed it'll bog down for and I have to push the gas pedal to make it run right.
P1648
P0601
If I remember right it's a powertrain control module internal malfunction and I think one is for a vac leak, but I can't remember for sure on the vac leak one. It has a small crack in the evap canister. Back in 05 it was in the shop for 5 weeks. The mechanic found the leak and said it wouldn't hurt it but they couldn't fix it. They had to change a bunch of stuff on it to get it to run. They changed an o2 sensor, cat converter, the map sensor 4 times then hard wired it per the dodge manufacture.
Old Nov 28, 2012 | 08:06 AM
grswat's Avatar
grswat
P1648
P0601
Vacuum leak would be my first guess. If the evap canister is leaking that'd be a good place to start. Both of those codes seem to be related to a failed pcm or possibly wiring.
If I read that right the map sensor is hard wired? Possibly throwing the codes or frying the pcm. I'm interested that the "manufacturer" suggested hard wiring the map.
Old Nov 28, 2012 | 05:13 PM
countryboy73
The guy that worked on the van was the shop manager for a dodge dealership. He said they called the manufacture to see if they coul help and they said to do it. Ill check the wiring for the PCM to make sure there's no bad connection. Is there any way to check the PCM. I traced the vac lines the best I could and found 3 short peices of rubber hose that was severely dry rotted and changed them but that didn't help.
