help on p0351/p0352 codes
Old Nov 27, 2012 | 07:36 PM
dsmblue's Avatar
dsmblue
Question help on p0351/p0352 codes
My wife just got start/run problems, and I pulled p0351/p0352 codes. Secondary resistance check across coil towers were 13.7/13.5/13.3k ohms, within spec. Coil pack was replaced in Oct. 2011, plugs and wires new just prior to that. Any ideas on what is causing this?
Old Nov 27, 2012 | 09:40 PM
Cougar41's Avatar
Cougar41
Model year? Are you getting ignition pulse to coils 1 & 2 from the PCM at coil connector? If not I would expect you have a bad PCM or wiring between PCM and coil.
Old Nov 27, 2012 | 09:59 PM
dsmblue's Avatar
dsmblue
MY2002. What is the best way to check pulse from PCM? Also, PCM was replaced in 2009.
Last edited by dsmblue; Nov 27, 2012 at 10:04 PM. Reason: fixed typing error, added info on PCM
Old Nov 27, 2012 | 10:38 PM
Cougar41's Avatar
Cougar41
Disconnect the ignition coil connector. Connect a test light to the contact for coil 1 and crank the engine. The light should blink as the engine rotates. Repeat for coil 2 and 3. If the light stays on or doesn't light at all the PCM driver circuit for that coil is toast or that wire is open or shorted. Check wire continuity.
Coil #1 - pin #3 dark blue with green tracer
Coil #2 - pin#4 dark blue with tan tracer
Coil #3 - pin #1 dark blue with orange tracer.
You can change parts yesterday and they can be bad today.
Old Nov 27, 2012 | 11:47 PM
dsmblue's Avatar
dsmblue
All leads check out OK. PCM appears to be fine. This leads me to believe the problem is in the coil pack. would you agree?
Old Nov 28, 2012 | 02:57 AM
Cougar41's Avatar
Cougar41
If they all blinked then yes, the coil pack.
