Dash Displays E CodE E 400.1 2002 GC Sport
Old Dec 17, 2012 | 02:28 PM
2therock's Avatar
2therock
Default Dash Displays E CodE E 400.1 2002 GC Sport
First time going after codes. Still not sure if this is the only way. I hear about doing three key switch cycles to the on position and wait. I have none showing by default. Will they display on their own if there is an issue?
You guys tell me.
This is a method I think I read from a Tizzy post.
I held the trip meter reset button in until I got the "SoF 4.1" in the display and let go.
Then I got "E CodE E 400.1".
Then "End" and the cluster went through a bunch of checks or calibrations of the Speedo and tach and cycled all the info icons. Looked Christmas like.
2002 Grand Caravan Sport.
EDIT! = I did the three key method and got a P1684. I see in the 2008 to 2010 Sticky its a battery has been disconnected in the last 50 starts which is accurate. I guess its the same for my 2002?
So lucky me eh?
Old Dec 17, 2012 | 04:20 PM
Tizzy1's Avatar
Tizzy1
Both issues could have been caused by the same occurance. The first item is the cluster self test. Code 400.1 is Improper power down detected. The P code is PCM or TCM, the P1684 is a TCM code for battery being disconnected. So if it was disconnected with the key on, it could give both codes. Neither of which I would worry about by the way.
Old Dec 17, 2012 | 05:07 PM
2therock's Avatar
2therock
Thanks!
