How to test fuel injector electrical without noid light
Old Jan 17, 2013 | 01:56 PM
Saxon's Avatar
Saxon
Default How to test fuel injector electrical without noid light
I have a 2003 Grand Caravan, and I need to test the #6 injector. Unfortunately, I don't have a set of noid lights. Is it possible to test using a multimeter from the connector that plugs into the PCM (comparing the resistance on the #6 circuit to a circuit I know is working properly)? If so, which pins on the connector would I need to test?
Old Jan 17, 2013 | 03:39 PM
Tizzy1's Avatar
Tizzy1
Injectors are 2 pin, you can ohm them for resistance, manual says 10 - 16 ohms. Otherwise pull the rail and crank it.
Old Jan 19, 2013 | 11:15 AM
LMPED's Avatar
LMPED
Originally Posted by Tizzy1
Injectors are 2 pin, you can ohm them for resistance, manual says 10 - 16 ohms. ....
Of course, this is on the injector side....
On the "driver" side, one pin is fed 12V full time with key ON, the other is the gorund side.... open unless engine is running...and grounded only milliseconds at a time from the "injector pulse"....
