97 grand caravan OBD code P1768
Old Feb 8, 2013 | 07:13 AM
rdrobertson15@yahoo.com's Avatar
Default 97 grand caravan OBD code P1768
97 grand caravan has ODB code P1768 - relays stuck open. Replaced the EAX relay and the code still came back. Could one of the other relays( fuel pump) be the issue?
The car was bucking about once every day or so but cleaning air intake and fuel additive seems to have cleared that up.
The tachometer never goes below 3000 although engine is not idling that high. Did have problem with indicator lights being intermittent and had to hit dashboard until taking it out and then pulling wiring taunt.
Old Jun 5, 2013 | 10:08 PM
richardcalderon09's Avatar
richardcalderon09
08 pickup ac works off and on the ac works but the blower stops what could that be
Old Jun 5, 2013 | 10:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
Richard
What are you working on or that you are having problems with? This way i can either help you or move your post to the correct section.
