Where to buy trans and shop REFUSES to flush trans?!?!
Old Mar 7, 2013 | 10:13 AM
tdidog's Avatar
tdidog
FYI, our 2005 Caravan has over 300,000 miles on it on the original transmission. I drop the pan and throw in a new filter and ATF +4.
Old Mar 8, 2013 | 07:15 AM
espacef1fan's Avatar
espacef1fan
Alright. I feel a bit better about the trans in this thing.
As for the trailer I wasnt going to go after that one specifically, I just wanted to illustrate the fact I wasnt going to be towing a gooseneck or something...haha
Old Mar 9, 2013 | 11:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
TNtech is right. You can always find someone to work on these transmissions. They are really easy to repair. I change the transission filter on my 1996 avenger every 15k and i still have the factory transmission. Besides if you need information on how repair your transmission, I can guide you thru the repairs.
Old Mar 10, 2013 | 01:52 AM
espacef1fan
Just realized/noticed TNTech isn't far from me. I live in Clarksville...LOL.
Anyways thank you everyone for all of the input/advice, I feel more comfortable with this van lasting now.
I am still looking for the most cost effective/best solution to firm up the rear suspension for towing/cargo in the back. I also haven't decided on what trans cooler I will go with.
Old Mar 10, 2013 | 10:21 AM
b1lk1's Avatar
b1lk1
Airbags and I use the stock transmission cooler when I tow and I usually tow around 4K lbs.
Old Mar 10, 2013 | 06:36 PM
steak59's Avatar
steak59
Lol, Just give TNtech a call, I am sure he'll hook you up and get it done right.
as for the suspension, I guess you can look into self Load Leveling Shocks. KYB makes them, I think even Mopar has them(which is probably made by KYB). Tho they are quite expensive.
As for the trans cooler, I think you will be fine just walk into the Part store and pick one that can fit in front of the condenser. But like many ppl said, if you are only towing a few hundred pounds, you'll be fine.
One of my Co-worker's dad is a plumber, he load up his van with steel pipes and tools every day, his van just hit 120k on original trans. Tho, he's pretty aggressive on changing the fluid every 30k miles.
Old Mar 11, 2013 | 12:54 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
As long as the previous owner didn't abuse the heck out of it, you should be fine for quite some time. I see these in the high 100s and 200s every day. It's almost never anything really serious. Keep in mind though it will nickel and dime you from time to time because it IS 8 years old with 155K on it. Even IF you ever had to put a tranny in it, you're still only out 4 or 5 monthly payments if you had a new one. I'll take that deal any day. Thats why my '97 truck gets resurrected constantly.
Old Mar 11, 2013 | 08:04 AM
espacef1fan
Oh, I am with you on the nickel and dime being cheaper. I have a 20+ yr old car you have never heard of(or atleast not recently..lol) as well : Merkur XR4ti. I'm in the beginning stages of swapping the engine out of it and swapping a turboed Duratec froma Ranger into it. So, I'm not scared of working on stuff. I just have a mistrust of automatic transmissions and a fear of being stranded on the side of the interstate..with my family, 400 miles from anywhere that would be a better place to break down.
Old Mar 11, 2013 | 08:11 AM
espacef1fan
Also, for the weight thing, I've thought about that too. I've had the van basically cubed out with luggage and wedding gifts, with my wife, my 2 kids and myself in it..and it did ok. So I guess I dont see why I should worry.
Airbags. Do you have a link or atleast some info on what you are using?
Old Mar 11, 2013 | 09:20 PM
steak59's Avatar
steak59
No air bags. Those requires pump and some complicated installation, it gets expensive.
I am talking about Self Leveling shocks where it has an internal pump that relies on the Jounce of the car to adjust height and pressure. Sometimes you have to drive the car few blocks for it to change height. They are direct replacement of your OE shocks.
A lot of the 08+ caravan comes with it from the factory, and it works pretty good.
http://www.amazon.com/KYB-SR2002-Specialty-Replacement-Shocks/dp/B001C9MRBS/ref=au_pf_pfg_s?ie=UTF8&Make=Dodge%7C40&Model=Grand%20Caravan%7C305&Year=2006%7C2006&carId=017&n=15684181&newCar=1&s=automotive&vehicleType=automotive http://www.amazon.com/KYB-SR2002-Specialty-Replacement-Shocks/dp/B001C9MRBS/ref=au_pf_pfg_s?ie=UTF8&Make=Dodge%7C40&Model=Grand%20Caravan%7C305&Year=2006%7C2006&carId=017&n=15684181&newCar=1&s=automotive&vehicleType=automotive
