Common issues to look for
Old Mar 14, 2013 | 10:00 PM
SilverSS's Avatar
SilverSS
Default Common issues to look for
Hey guys. My girlfriend got hit last weekend and insurance totaled the car she had today. She decided she wants to get a minivan. I found what appears to be a good deal on a 98 Caravan Sport. It has the 3.8 V6 and 127,000 miles. Going to look at it tomorrow. Are there any common problems or things to check? Any certain years to avoid? Thanks .
Old Mar 15, 2013 | 12:26 AM
steak59's Avatar
steak59
well... it is a 15+ years old car, you better embrace yourself for ANYTHING that could break down.
Old Mar 15, 2013 | 08:59 AM
SilverSS's Avatar
SilverSS
Yep unfortunately I'm used to that lol. The newest vehicle I have is my 98 Ram with 169,000 miles on it. I've done about everything on a vehicle short of rebuilding an engine or trans but I've swapped them out before. Just didn't know if there were problem areas to be aware of. I know on the Ram the plenum gasket, trans check valve, etc needed to be taken care of. So far the truck has been great- required very little after the common problems were fixed. I read somewhere a long time ago to avoid the 3.0 or 3.1L motor and the transmissions in certain years but didn't state what years...
Old Mar 15, 2013 | 10:50 AM
christheman's Avatar
christheman
The 1997 Caravan/Voyager, and perhaps the rest of the 3rd Generation years, had the 3.0L engine - oddly made by Mitsubishi. That was considered to be a problem engine by many at the time.
Old Mar 17, 2013 | 10:03 AM
td1's Avatar
td1
ok!!! heres my (10 point) short list!! (i have a forest green, 1996 GC, ES, 3.8L, btw)
1) new tranny in the next 20K
2) clock-spring/cruise control
3) drivers door power window
4) in tank fuel pump @ 160K
5) starter soon
6) if its green, the paint is already peeling/flaking
7) rear vent power window motors will go out soon
8) new battery
9) AC may not be blowing as cold as originally
10) i had to replace BOTH ecu modules two months ago, you will most likely not have to do this. before i had this forest green, 96, ES, 3.8L....i had the SAME van, in every detail, however i never had any ECU issues. i think a heat wave wiped out mine this time.
Old Mar 17, 2013 | 12:20 PM
td1's Avatar
td1
11) the headliner fabric will start to fall.
td1
Old Mar 18, 2013 | 06:40 PM
td1's Avatar
td1
12) new starter
Old Mar 18, 2013 | 06:42 PM
td1's Avatar
td1
13) new headlight assemblies (to replace the fogged up ones)
Old Mar 18, 2013 | 11:15 PM
td1's Avatar
td1
127K?
12) new struts.
Old Mar 19, 2013 | 05:18 PM
b1lk1's Avatar
b1lk1
Strut towers like to rot out.
