09 Caravan shifter question
Old Mar 15, 2013 | 04:40 PM
Daleford's Avatar
Daleford
Default 09 Caravan shifter question
I bought a used 09 Caravan SE without an owners manual. I am assuming this is a 4 speed transaxel on mine. I notice there are 2 high gears. A "D" with a circle around it and a "4" with a circle around it. While driving and shifting from one to the other I see no difference in engine RPM...
Is one of those used to lockout the overdrive? I ask this because I may be doing some light short range towing an don't want to be in overdrive.
Old Mar 15, 2013 | 06:39 PM
vonJaerschky's Avatar
vonJaerschky
I can't answer your question, but you can download an owners manual here.
Old Mar 17, 2013 | 09:55 AM
Daleford's Avatar
Daleford
OK I read the transmission section throughly. Chrysler doesn't even mention the "4" gear that I see on my dash! They say while in drive you move the shifter left to go from "D" to "3". OK That works. Also you can hit the shifter again to drop down to "2", if you need to. When you move the shifter the other direction you come up through the gears. However, instead of going from "3" back into "D", you go into "4"!
What is that "4" thing? And why does it only show when you are moving the shifter to the right?
Old Mar 18, 2013 | 12:31 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you send me a pm with the last 9 of the vin and mileage, I can send you all the information you need about your van.
Old Mar 21, 2013 | 09:39 AM
Daleford's Avatar
Daleford
Sorry for delay and than you for the help. Here is the vin:
---- 29R518584
All I really want to know is what is that "4" gear all about?
Old Apr 21, 2013 | 10:51 PM
46FD04's Avatar
46FD04
@ Daleford
I own a 2009 Caravan with 4-speed tranny.
Mine does the same thing; has gears 1, 2, 3, 4, and D
The way I understand it is your tranny will shift thru all 4 gears when you are in 4 or D.
Why? I have no idea, I just live with it.
Also, be careful with your shifter. I've had mine replaced twice.
1. I couldn't use the Auto-Stick feature (it wouldn't manually shift gears)
2. The shifter broke inside, and I could only use N and D. I had no Reverse or Park.
Both times, Dodge Mechanics told me to GENTLY shift the gears and not to slam the shifter down into Drive, or slam it up into Park.
Old Apr 22, 2013 | 07:40 AM
Daleford's Avatar
Daleford
Finally, an answer. Thank you. I thought there had to be another 09 4 speed out there somewhere. I have not go to visit my dealer yet but it seems 4 or D = same thing. Wierd!
