Power Outlets Dead, Fuse OK
Old Apr 7, 2013 | 10:42 AM
Izzy1's Avatar
Izzy1
Default Power Outlets Dead, Fuse OK
Mine is a 1999 Grand Caravan. Kids put a metal object in the dash power outlet (cigarette lighter). Both dash and rear outlets stopped working. Fuse, right? But the "cig lighter/accessory" fuse is fine. I replaced it just in case -- both outlets still dead. What could it be?
Thanks!
Old Apr 7, 2013 | 11:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would remove the outlets and check the wires for power and ground. If you have power and ground, then i would replace the outlet.
Old Apr 8, 2013 | 09:43 AM
Izzy1's Avatar
Izzy1
Thank you for your response. OK, I'll do that, but how would that explain both outlets being dead?
Old Apr 8, 2013 | 10:19 AM
master tech
If you don't have power and ground, that maybe the reason both are dead. Wiring or another fuse that controls that circuit.
Old Apr 14, 2013 | 02:34 PM
Izzy1's Avatar
Izzy1
OK, here's what I did:
1) Checked a 9-volt battery with multimeter - 9v fine. Then checked from positive of that battery to ground of both outlets: nothing with the key in either OFF or ACC position.
2) Still in DC voltage mode, checked outlets with key OFF. Nothing but parasitic fluctuations of a dozen millivolts. However, with the key in ACC both outlets run up to about 390 mV and hold there; once the key is turned off, the displayed voltage slowly ratchets back down to about a 100 mV. What could this mean?
Compounding the problem is that I can't find a wiring diagram that shows power outlets. My Haynes manual doesn't seem to have them either on the chassis diagram or any other. Or am I looking in the wrong place?
