2007 Grand Caravan p0480 code plus temperature light is on
Old Apr 8, 2013 | 10:35 PM
deemarie2009's Avatar
deemarie2009
Default 2007 Grand Caravan p0480 code plus temperature light is on
The check engine light has been on for about a week(has been on 2x before and it was emissions stuff so I still drove it on vacation which was about 400 miles, tonight the temperature light went on and the guage was on hot. It was low on oil (about a month ago vavoline said it is not leaking oil but burning a quart about every 1500 miles) Tonight Advance Auto said it gave a code of p0480 cooling fan 1 control circuit malfunction. Wondering how much is this going to be to fix and how hard is it to fix, the van has 115,500 miles on it. Any help/ideas would be great!
Old Apr 8, 2013 | 11:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
Symptom:
P0480-COOLING FAN 1 CONTROL CIRCUIT
When Monitored and Set Condition:
When Monitored: With the ignition on. Battery voltage greater than 10 volts.
Set Condition: An open or shorted circuit is detected in the radiator fan relay control
circuit system. One Trip Fault.
POSSIBLE CAUSES
RADIATOR FAN RELAY INTERMITTENT OPERATION
INTERMITTENT CONDITION
GROUND CIRCUIT
FUSED B+ OUTPUT CIRCUIT
POWERTRAIN CONTROL MODULE
RADIATOR FAN RELAY CONTROL CIRCUIT SHORT TO GROUND
RADIATOR FAN RELAY CONTROL CIRCUIT OPEN (IPM)
RADIATOR FAN RELAY CONTROL CIRCUIT OPEN (PCM)
RADIATOR FAN RELAY CONTROL CIRCUIT SHORTED TO GROUND (IPM)
RADIATOR FAN RELAY CONTROL CIRCUIT SHORT TO GROUND (PCM)
INTEGRATED POWER MODULE (OPEN)
INTEGRATED POWER MODULE (SHORD)
TEST ACTION APPLICABILITY
1 Turn the ignition on.
With the DRBIIIt, actuate the Radiator Fan Relay.
Are both Radiator Fan operating?
All
Yes ! Go To 2
No ! Go To 3
2 Turn the ignition on.
Wiggle the wiring harness from the Radiator Fan Relay to the PCM while the relay
is actuating.
Did the Radiator Fan Relay stop when wiggling the wiring harness?
All
There is more information, If you need the rest. Just let me know.
