99 Caravan problem
Old Apr 16, 2013 | 08:40 PM
Jersey powersports's Avatar
Jersey powersports
Default 99 Caravan problem
I bought this 99 AWD caravan with the fuel pump wine from hell , I was told it was the Fuel pump anyhow , SO i get a New Pump put it in start it up and nothing changed GRRRRR when i step ont he gas it goes away , let off whineeeeeeeeeeee LOUD . what else could that be { besides a bad NEW pump }
Old Apr 17, 2013 | 12:15 AM
master tech's Avatar
master tech
Site Moderator & Tech
Can you isolate the sound from the fuel tank?
Old Apr 17, 2013 | 12:05 PM
Jersey powersports
It is from that area . if this will work its a video of the sound . its on my facebook https://www.facebook.com/photo.php?v...type=2&theater
it is hard to work under there without a lift
Old Apr 17, 2013 | 03:35 PM
Tizzy1's Avatar
Tizzy1
possible the fuel line is contacting the frame or body somewhere and transferring the pump noise.
Old Apr 18, 2013 | 08:43 AM
Jersey powersports
well never Liston to a shop, the shop I bought the van from told me it was the fuel pump , thats why i changed it , after looking I found a vacuum can next to the take one of the lines were leaking , that was the sound { got to say that was one loud sound for a leak } the good news is the new pump only cost 50 bucks. I also fixed the ground cable { i dont get how a ground going to a plastic tank grounds anything } the tank and sender are both plastic . but it works , thanks for the reply's
Old Apr 18, 2013 | 04:29 PM
Cougar41's Avatar
Cougar41
Rub a balloon on your shirt and you get static electricity. No metal there. I would imagine that's what your ground is for.
