Squeak Center Dash Only With A/C (1994 Caravan, 3.3L)
Old May 29, 2013 | 11:46 AM
dwnowhere1's Avatar
dwnowhere1
Default Squeak Center Dash Only With A/C (1994 Caravan, 3.3L)
ONLY with the A/C on, and mostly starting from a dead stop, but also when running at a high speed (over 50 mph)) I get an intermittent sound like a dry blower fan bearing coming from center dash area in CAB. Noise cannot be repeated with vehicle running,
A/C on, and foot on the brake. Replaced the blower and noise still there.
Master Tech posted a TSB for 2001-2002 Caravans (other thread) but before I put forth effort anyone know if similar TSB for 1994 or experienced same and what is the cause.
Old Jun 6, 2013 | 07:54 AM
dwnowhere1's Avatar
dwnowhere1
bump1
Old Jun 7, 2013 | 10:53 PM
dwnowhere1's Avatar
dwnowhere1
I found this post by mastertech re 1998 Caravan. Anyone know whether it applies ot the 1994.
https://dodgeforum.com/forum/dodge-c...or-damper.html
Old Jun 11, 2013 | 11:12 PM
dwnowhere1's Avatar
dwnowhere1
TSB 24-12-94 Appears to address my problem
Anyone made a repair under this TSB, and if so can you recall and describe the evaporator sounds you were hearing?
Thanks
David
