Airbag light
Old Dec 30, 2013 | 09:36 PM
  #21
trophyslayer's Avatar
trophyslayer
Originally Posted by Cougar41
Code definitions according to the Actron website:
Code 34 - "First Row Passenger Seat Belt Sensor Short To Ground"
You could disconnect the negative battery cable, wait 2 minutes then inspect the wire harness and connection to the passenger seat belt tensioner.
Code 64 - "Right Side Satellite Acceleration Sensor (SAS) #3 Loss Of Communication Diagnostic Code"
I haven't got a clue.
well glad to say that the connector was the main problem, I still was experiencing intermittent airbag light, on-off with in 30secs, usually when turning/shifting weight, however, i knew it was not the connector at this point, after jacking the front of the van up, turning wheel lock to lock, giggling the wires I could not replicate it
finally got a reader that could pull the Chrysler code "Launch X431 Creader Viii" got it from amazon for those who want to to know works great for the 06 and has lots of functions, got it for a bit less then 200, I think they have it listed for more atm.
anyway pulled the codes
first row dirver seat belt pretensioner open
and
squib configuration mismatch
figured the issue would be near the pretensioner
pulled the battery, removed the side of the seat, noticed the large rubber grommet of the cover to the seat belt sheath pressing against the top of the tensioner connector(had the seat motors replaced under warranty) tested the tensioner with my multi meter, got around a Resistance of about 2 Ohms (thats fun pressing down that shorting bar while holding the probes in place)
so I put the connector back on,
Properly positioned that large thick cover of the belt sheath
and guess what, 3 weeks not a single airbag chime, before I was getting at least once per day
thanks again for all the help on this awesome site, sorry I haven't been around much lately, things have been going good, just had my 4 year cancer free
I still use the knowledge you all share, and am extremely grateful for all the help
Old Dec 30, 2013 | 09:46 PM
  #22
master tech's Avatar
master tech
Site Moderator & Tech
Welcome back. Glad you able to find the problem. And Congrats on you 4 years of being cancer free.
Old Dec 31, 2013 | 11:06 AM
  #23
Tizzy1's Avatar
Tizzy1
Congrats on both as well!!
