2000 Caravan electrical
Old Jun 4, 2013 | 11:53 PM
barkleyroyer's Avatar
barkleyroyer
Default 2000 Caravan electrical
A few months ago I started having problems.
1.First the heater motor would work intermittatly, now it does not work at all. 2.Rear side window Driver side worked intermittatly, now does not work at all.
3.Odometer digital readout is intermittent.
4.Passenger power window is intermittent.
5. Digital read out on radio is intermittent.
Any Ideas. Yes I have checked the fuses.
Thanks in advance, Rick
Old Jun 5, 2013 | 10:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Hi Rick
Welcome to Dodge Forum
You could be having a bus failure. Have had the van checked for active or stored codes?
Old Jun 6, 2013 | 07:54 PM
barkleyroyer
No I haven't yet. Now the radio and door locks have dropped off working. The door locks only work now when running now. Also, I pushed the A/C button last night to see if that light worked. It no longer does light up. Bought a Haynes book and will be working on if off and on this weekend as time allows.
Rick
Old Jun 6, 2013 | 08:30 PM
Cougar41's Avatar
Cougar41
Considering your symptoms the first place I would look is the heater A/C (HVAC) control panel connector. It's been known to melt, distort the contacts and bring the PCI data bus to it's knees.
