Passenger Sliding door
Old Jun 7, 2013 | 12:27 AM
VolvoT5's Avatar
VolvoT5
Default Passenger Sliding door
My passenger door is acting up. First it will not lock or unlock. I think I need to replace the actuator. Now if I press to open the door it will open 1/4 and it will stop. I will open the door all the way manually and when I try to close it will make a sound and that's about it. I opened and closed it manually a few times and now it opens fully but it doesn't closed. If I try with the remote it opens but doesn't close. If I try on the rear button it opens but it doesn't close. If I try from the front switch it opens and closed. If I open from remote or rear it opens but it would not close from the front switch.
I really need to fix this since we are about to have our first baby and it would be helpful
Its a 2006 Grand caravan sxt
Thanks in advance
Old Jun 7, 2013 | 11:20 AM
Tizzy1's Avatar
Tizzy1
You are correct on the lock actuator needing replacement. The power issue is most likely a broken wire in the track harness. (the harness that runs in the lower door track opening) You can get a new one (kind of expensive) or remove the old one, open it up and replace the broken wires.
Old Jun 7, 2013 | 03:11 PM
VolvoT5's Avatar
VolvoT5
Thanks. I will try to work on it this weekend
Old Jun 12, 2013 | 08:39 PM
VolvoT5's Avatar
VolvoT5
Im ordering my parts for the actuator. Mpar of $86 OTD with 1 year warranty or the Doorman brand $66 with lifetime warranty?
Old Jun 13, 2013 | 12:30 PM
Tizzy1's Avatar
Tizzy1
$86, that's cheap. I show list price at $120. So I'd go with the aftermarket part at this time. Gonna try to repair the door track harness?
Old Jun 13, 2013 | 01:51 PM
VolvoT5's Avatar
VolvoT5
I end up getting the Mopar since there is alot of bad reviews for the aftermarket. I will try to fix the track harness and if I'm not able to fix it I will order a new on ebay. I saw one for $48 with no plastic track
Old Jun 14, 2013 | 10:48 AM
Tizzy1's Avatar
Tizzy1
so you have to put your plastic track on it?
Old Jun 14, 2013 | 02:20 PM
VolvoT5's Avatar
VolvoT5
That is correct. Im asssuming to use your old one? I found one on sale from Dorman at $64 for left and $63 for right.
I would need the right am I correct? It Passenger side is what I need
Old Jun 14, 2013 | 02:51 PM
Tizzy1's Avatar
Tizzy1
yep. Right and left in a vehicle is always as you are sitting in the drivers seat. I guess it's worth the savings to put in a little extra work.
Old Jun 17, 2013 | 11:23 AM
VolvoT5's Avatar
VolvoT5
Was able to fix the wire. It was almost in the middle. I't took me a while to gifure out how to change the actuator on the passenger side. Good thing for you tube. I was able to dril a small hole in order to access the t15 screw
Thanks for your help
