05 Caravan won't crank
Old Jun 23, 2013 | 01:14 PM
300zx's Avatar
300zx
Default 05 Caravan won't crank
This is my first post, so any help would be great. I will try to be as detailed as possible.
Initial indication: Turn key and gauges come on and power inside van as normal, but van will not crank. Thru reading posts and doing some research, I've been able to troubleshoot and verify battery, starter, and fuel pump are all good. I've checked all fuses in the IPM.
The specific problem seems to be Starter and Fuel pump relays are not receiving power when the Key is in the on or start positions. When I say relays are not receiving power, I mean on pin 85 of both relays. Pin 30 has power on both relays.
I have tried starting in both park and neutral
I tried to see if any codes would come up by turning ignition switch on and off 3 times, but only see mileage displayed
I replaced FCM with no changes.
Any suggestions are greatly appreciated.
Old Jun 24, 2013 | 09:18 AM
2therock's Avatar
2therock
Are you getting a clicking noise?
Old Jun 24, 2013 | 01:14 PM
300zx's Avatar
300zx
Yes, in the IPM, but I think it is from the accessory relay
Old Jun 25, 2013 | 08:48 AM
2therock's Avatar
2therock
I don't know what an IPM is. But some of these vans starters get the click of death being the solenoid contacts are worn.
If that be your case, 2 hours and an $80.00 starter or 3 hours and $20.00 in parts.
Good Luck, Let us know.
Old Jun 25, 2013 | 11:59 AM
300zx's Avatar
300zx
The IPM is where the Relays and fuses are located under hood. I know the starter is good because I jumpered the relay and the engine will then crank. That is why I need to know where the signal goes when the key is turned to the start position. The starter relay and fuel pump relays do not get energized. I'm thinking it may be the computer (PCM), but have no way to verify. That is where I was hoping someone in the forum could point me in the direction to test it. Thanks
Old Jun 25, 2013 | 06:54 PM
Cougar41's Avatar
Cougar41
Would you like the wiring diagrams? Send me a private message and include an email address. Click "User CP" at upper left then in left column under "Private Messages" click "Send new private message".
Old Jun 27, 2013 | 02:29 AM
Cougar41's Avatar
Cougar41
Just sent 4 diagrams.
Old Jun 27, 2013 | 03:15 PM
300zx's Avatar
300zx
IT'S FIXED, turned out to be the ignition switch. Thanks Cougar41!
Old Jun 27, 2013 | 05:42 PM
Cougar41's Avatar
Cougar41
Great news. Glad to hear your headache is over. Yours and hers.
