check engine light
Old Aug 7, 2013 | 12:17 PM
kwchoi's Avatar
kwchoi
Default check engine light
Hi,
97 gr caravan, 300,000km
A quick question: Is there any difference between using the code reader to clear the code and disconnect the battery?
Thanks in advance.
Old Aug 9, 2013 | 11:33 PM
master tech's Avatar
master tech
Site Moderator & Tech
They both will clear the memory. The code reader would be better, but it only clears the codes in the engine controller. Not the other controllers.
Old Aug 10, 2013 | 01:31 PM
Cougar41's Avatar
Cougar41
Another aspect? Thousands have disconnected the battery for any number of reasons without mishap. I know I have. On very rare occasions it can create problems. If you have a choice use the scanner.
Old Aug 11, 2013 | 09:38 PM
kwchoi's Avatar
kwchoi
Thank you, MasterTech and Cougar41.
