Fix 1 another quits
Old Aug 11, 2013 | 08:12 PM
Gwshell819's Avatar
Gwshell819
Default Fix 1 another quits
My 98 gc gauges stopped working I found bad solder on cluster now all works except my speedo is incorrect.
Old Aug 11, 2013 | 09:17 PM
Gwshell819's Avatar
Gwshell819
I just solder what looked like bad joints on instrument cluster. Put back in all gauges work now but speedo reads wrong. It doesn't register until I do about 20 then it starts moving but is not correct speed. What did I solder that I shouldn't have?
Old Aug 11, 2013 | 11:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
It maybe just a bad circuit board. And soldering the circuit board isn't going to help. I would replace the circuit board.
Old Aug 12, 2013 | 12:14 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Sometimes you get lucky with those and it's just the solder spot, but if the copper "trails" are degraded or the board has been flexed too much, you'll make it worse.
