2003 Grand Caravan Sport ABS Codes Help!
Old Nov 5, 2013 | 06:23 PM
buganddoug's Avatar
buganddoug
Default 2003 Grand Caravan Sport ABS Codes Help!
On my Wife's 03 Grand Caravan Sport with 3.3L Flex Fuel with 110,000 miles on it. The ABS Light cam on and I had codes
02 Left Front Wheel Speed/Signal Malfunction
04 Right Front Wheel Speed/Signal Malfunction
10 Valve Power Feed Malfunction ( came on after I replaced speed sensor)
11 Electronic Control Unit Internal Malfunction
I OHM out the driver side sensor and it is 1283 ohm's and passenger ohm out 0.00 I check it more than once and it is 0.0 ohm's.
So I put a new Mopar right front abs sensor in. It read 1285 ohm's.
Drove the van and light is out and ABS doses work. I tested it on a dirt road by my house. But the codes would not clear.
Now the ABS Light comes on and off and driving me crazy.
I took out the Power distribution center to check for corrosion and cleaned where I saw corrosion. Put it all back together and ABS Light was out for about 20min and now back on.
I hope someone here can help me. I just got back to work and do not have a lot of money to spend.
Old Nov 5, 2013 | 10:29 PM
buganddoug's Avatar
buganddoug
If I do key on key off three times I get no codes done.
Old Nov 5, 2013 | 11:14 PM
master tech's Avatar
master tech
Site Moderator & Tech
To clear ABS codes, You should have a scanner.
