2010 Dodge Grand Caravan, Brake System Warning Lights
You have to take the wheel, caliper and brake rotor off the car. Then the shield is held on by 3 10MM head screws. No biggie, although a wheel speed sensor shouldn't be buried like that. It's kind of stupid.
If the wheel bearing has any play in it, you'll need to do the hub as the pickup wheel for the sensor is inside of it. A loose bearing will make it read intermittent. If you get the sensor from a dealer, the catalog says to replace the brake line with it....it's not necessary. If you buy a wheel hub from a dealer, the catalog will tell you to replace both sides...you DO need to do that. I think they changed the pickup wheels.
