[4th Gen : 01-07]: 02 Dodge Grand Caravan ABS and Brake light ON.
Hi All,
After much reading through the forums i checked my fuse's, connectors for corrosion and ensured i had power at the abs controller socket on pin 9,10,24 and ground on pin 1 and 16. Obviously when i disconnect the unit the lights go away but i would prefer the abs to work.
When i read the code with my basic innova reader for abs it says code 10.
From my understanding and reading the forums its caused by a power failure to the controller but i have verified that.
Needless to say the lights are becoming annoying and i would like to fix this problem but im not sure where to go to now. Is it likely the problem is within the ABS controller or with the unit itself?
Any help would be great, thanks in advance
Fixed at last
I finally found the issue and figured i would share as i havent seen this fix posted here, i realised i had overlooked the obvious testing.
Still thinking about why its claiming a power failure to the controller i decided to again check the supplies, indeed it was showing 12v on 9,10 and 24 but this time i decided to check the resistance of each wire from the ABS module plug to C4 on the power dist fuse box. PIN 10 an 24 were almost 0 ohms but 9 had a resistance of 5 ohms.
Im not entirely sure how it still shows 12v with a 5 ohm resistance in the circuit but splicing in a new wire from pin 9 on the ABS module plug to pin 8 on C4 fixed the issue.
Now the lights go out and ABS is 100% again!!
