[3rd Gen : 96-00]: help- 98 3.0L AC belt pulley noise
Old Apr 6, 2014 | 05:09 PM
doanhtran's Avatar
doanhtran
Default help- 98 3.0L AC belt pulley noise
I could use some suggestion for this irritating little problem on my 1998 caravan 3.0l Mitsubishi engine.
I was installing the valve cover gasket to reduce the oil leak and thus I figured might as well replace the two belts since they are old and off the car at the moment.
When I put everything back and ran the car, I hear this squeaking noise that was not there before.
I know I am not putting the right tension on the AC belt but I cannot find anywhere how to set the right tension with the adjusting nut before I torque the set bolt to 40 ft lbs.
I have tried searching a few forums but not much info on how to set the correct tension on the AC belt.
can someone give me a hint please?
Old Apr 7, 2014 | 01:01 PM
tjnc's Avatar
tjnc
I have a '98 SE with the 3.0l. I wasn't even aware you could adjust it.. Mine is just a spring loaded wheel that pushes the belt out as far as the belt lets it. Maybe the belt is too loose?
I actually bought the $106.00 kit front advance for mine and need to install it this week. Supposedly this kit fixes a belt slip issue that OEM stuff doesn't..
Spray water on the belt while the van is running, if it goes quiet it's the belt.
Old Apr 7, 2014 | 11:22 PM
doanhtran's Avatar
doanhtran
this is the AC belt I am talking about. the main serpentine belt has its own tensioner that you do not adjust.
everywhere I search, I see this but it tells me nothing.
"Adjust to specification by tightening the adjusting screw. "
Attached Thumbnails help- 98 3.0L AC belt pulley noise-2007-06-19_210104_1998caravan3.0acbelt.jpg
Old Apr 8, 2014 | 11:02 PM
tjnc's Avatar
tjnc
How about right 2/8 till it stops squeaking/slipping? The belt is either too lose or too tight, probably too loose. You likely won't find the actual spec unless you have a mopar or hayes manual handy..
UPDATE: Did mine today. counter clockwised the bolt up about 1/4, loosened puller bolt, took belt off, later after other work: put belt back on, tightened pulley till about the torque it was when I took it off(judging from turn power), used ratchet to tighten adjuster bolt till it was snug and kept tightening ~3/16 till I could barely flex the belt. Seems to run fine.
