[4th Gen : 01-07]: p0455
Old Apr 7, 2014 | 08:53 PM
Bens's Avatar
Bens
Default p0455
Is it likely that a p0455 code in the 2002 grand caravan sport 3.3 could cause a p0442 to pop up?
Last edited by Bens; Apr 7, 2014 at 10:03 PM. Reason: put in the wrong code number
Old Apr 8, 2014 | 04:00 PM
Cougar41's Avatar
Cougar41
Yes:
Old Apr 9, 2014 | 06:38 PM
Bens's Avatar
Bens
I found that the evap test line was not connected under the air filter box. A 5/16 hose about 2" long that connects it to a steel line was dry rotted and split. Also I found a small line coming from under the brake reservoir(which originally comes from the top of the intake into a tee) to be broken. It has 90 degree ends and plugs in behind the battery. It's hard plastic. Maybe 6" in length. I'm not sure what it's called that it is connected to. It appears to be connected to the throttle/cruise control cables. Any links I can follow or ideas what that line may be running from? I'm hoping this is the cause of the 2 codes.
