[General]: 09 Grand Caravan ABS/Brake/EPS BAS light on
Old 04-17-2014, 01:28 PM
rlh7974's Avatar
rlh7974
rlh7974 is offline
Default 09 Grand Caravan ABS/Brake/EPS BAS light on
Just today, got into van and heard a chime as I accelerated down the street. The above mentioned lights came on, with the traction car light, as well. This has never happened before. Didn't know if this was common for this van. It will flip 100k within a couple of weeks, most likely. Any input to rule things out, before the dealer robs me?
Old 04-17-2014, 03:20 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
A few options. Check applicable fuses. Inspect electrical connections on the ABS controller and wheel speed sensors. Make sure sensors are free of any road debris. Connect a scanner capable of reading ABS codes and come back here with the codes.
Sure not absolute but the two times I've read about this fault they changed the ABS controller to fix it. It can go away for a while but usually returns.
Old 04-17-2014, 03:42 PM
rlh7974's Avatar
rlh7974
rlh7974 is offline
Thanks! We are taking it to be scanned this afternoon.
Old 04-17-2014, 05:02 PM
rlh7974's Avatar
rlh7974
rlh7974 is offline
Code: 2200
Old 04-17-2014, 06:35 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
Hint: It's almost never A,B,C or D. You can replace the ABS module yourself, but it will have to be "Initialized" with a scan tool for ESP and steering angle calibration.
28 - DTC-Based Diagnostics/MODULE, Antilock Brake (ABS)/Diagnosis and Testing
C2200-ANTI-LOCK BRAKE MODULE INTERNAL
  • When Monitored: With the ignition on.
  • Set Condition: When the Anti-Lock Brake Module detects an internal fault, the DTC is set.
Possible Causes
WIRING HARNESS,
TERMINAL, CONNECTOR DAMAGE
FUSED B+ CIRCUIT(S) SHORTED TO GROUND, VOLTAGE, OR OPEN
GROUND CIRCUIT(S) OPEN
1.CHECK FOR A DTC C2200-ANTI-LOCK BRAKE MODULE INTERNAL
NOTE: This DTC must be active for the results of this test to be valid. 1. Turn the ignition on. 2. With the scan tool, read and record DTCs. 3. With the scan tool, read and record Environmental Data to help identify the conditions in which the DTC was set. 4. With the scan tool, erase DTCs. 5. Cycle the ignition switch from off to on. 6. With the scan tool, read and record DTCs
Does the scan tool display: C2200-ANTI-LOCK BRAKE MODULE INTERNAL?
Yes
  • Go To 2
No
2.CHECK THE WIRING HARNESS, TERMINALS, AND CONNECTORS 1. Turn the ignition off. 2. Visually inspect the related wiring harness. Look for any bruised, chafed, pierced, or partially broken wires. 3. Visually inspect the related wiring harness connectors. Look for broken, bent, pushed out, or corroded terminals.
Were any problems found?
Yes
No
  • Go To 3
3. FUSED B+ CIRCUIT(S) OPEN OR HIGH RESISTANCE
1. Disconnect the Anti-Lock Brake Module harness connector. 2. Using a 12–volt test light connected to ground, check the (A200) Fused B+ circuit.
NOTE: The test light should be illuminated and bright. Compare the brightness to that of a direct connection to the battery.
Is the test light illuminated and bright?
Yes
  • Go To 4
No
4.GROUND CIRCUIT OPEN OR HIGH RESISTANCE
1. Using a 12–volt test light connected to 12–volts, check the (Z107) and (Z127) Ground circuits.
Yes
No
Old 04-18-2014, 01:39 AM
rlh7974's Avatar
rlh7974
rlh7974 is offline
Thanks for your help! This might be above my head. 😔
Quick Reply: [General]: 09 Grand Caravan ABS/Brake/EPS BAS light on
