[4th Gen : 01-07]: 2003 Dodge Grand Caravan 3.8 Ex Error P0305
Old May 21, 2014 | 04:30 PM
wsy1004's Avatar
wsy1004
Default 2003 Dodge Grand Caravan 3.8 Ex Error P0305
Check Engine light is on. Went to Advance Auto to verify and it was a misfire on injector 5. So, I thought maybe a changing the spark plugs and wires needed to be done since it was due anyways. Completed and the check engine light is still on. My thought, if I was getting a misfire on fuel injector 5 I should be losing some power when I hit higher speeds. (Right). But not the case. It is responding with a kick. I noticed that the spark plugs and wires did do the job. Anyways, check engine light is still on and its bothering me. Spoke to a friend and he told me to check with the fuel injector connector harness. He mentioned that sometimes the wires can get fried and cause the problem. Ok. So, I had to purchase plenum gasket set and started from there. I removed the plenum and found the wires that connect to the fuel injectors to be somewhat in bad shape. Thought about using electrical tape to tape up the wires but thought Nah, better do it right. Called a local Dodge dealer that sold me the complete wire harness for the fuel injectors for about $200.00 not sure if the price was good or not but had to do it anyways. Installed and noticed that the check engine light had gone away. Not sure if that was normal or not. Grand Caravan is driving great. Spent about $300.00 dollars and used about 4.5 hours of my time. I shall be back in a couple of days to let you guys know if the light comes back on or not.
Old May 21, 2014 | 11:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
The injector wire problem was only on a few years 2002 thru 2005. You should have had a P0205 for the injector. I believe that was a good price for the wire harness. Keep us posted. Good Job!
Old May 22, 2014 | 03:12 PM
Cougar41's Avatar
Cougar41
What matters? You did a great job fixing it. Here's a few details:
As MT eluded to the P0305 code is a catch all for any cause of a misfire meaning spark, fuel, compression. A P0205 narrows it down to just the fuel injector circuit
http://www.obd-codes.com/p0305
http://www.obd-codes.com/p0205
The fuel injector harness melting on early/mid 4th generation is an all too common problem. Here's a thread that tells you everything you would want to know about it including how you could have saved the $200 bucks.
http://forum.chryslerminivan.net/sho...wn-and-Country
Old May 24, 2014 | 11:45 AM
wsy1004's Avatar
wsy1004
Today is May 24, 2014. The engine light came back on after a day. Here are things that I have done to the engine, change the spark plugs and wire, change the fuel injector on 5, change the fuel injector wiring harness, and changed the coil pack. Cougar41 showed me some great additional information for possible causes. I will take a look at spark plug #5 to make sure it doesn't look bad? It could be a possibility? But not certain. Will look at other suggestions in the link given by Cougar41. Thanks. Will let you all know the details.
