[5th Gen : 08+]: 08 grand caravan 4.0
I just read a write-up about this today. Google "2008-2014 Chrysler and Dodge minivan shifter fix / repair" (include the quotes) to find the article. The article says it is caused by a bad switch actuator in the shifter. It claims that removing then replacing a 10 amp fuse in the TIPM (fuse box) will allow you to remove the key. I have included a picture of the my TIPM with the 10 amp fuse (red) highlighted.
Please let us know if removing the fuse actually works.
![](https://lh5.googleusercontent.com/-eOkn_PcSd-Y/U31QeaRStFI/AAAAAAAAApQ/wFBf9qKZSLk/s600/Fuse%2520to%2520remove%2520for%2520FOBIK.jpg)
The manual list that fuse as fuse M27, 10A, Ignition Switch and Window Module.
George
George
on
Have had problems with the windows rolling down or up? Or no radio? If you have had these problems, remove the ring on the ignition and pull out the metal ring that dealer installed. And put the black ring back on. The ignition recall was only to install the metal ring so the fob wasn't easy to pull out. The module wasn't replaced. The dealer is to hook up a scanner and find out which company made the modules, there were only two company's. Only one of them got the metal ring and other did not apply.
I did not force it just keept working it on/off finally it came out no recall that I know of,it has been starting hard just cranks no start then it takes off.it been doing that for a year dealer cant find anything wrong now maybe its been the switch,calling dealer tomorrow, thanks guys Rick ncpa
on
Trending Topics
I took the van to the dealer today he said its the shifter module ,something to do with it,its going to cost $300 to fix it have to take it back tomorrow,told him fix it I cant be messing with it. is that too high price to repair? I though it was but need it fixed. Rick
took van to dealer for ignition key coming charged me $390.00 for shifter switch,key works good now,but this morning my brake light,skid light,other lights on in dash the dealer might be the brake module but I didn't have the money for him to test the module they wont check it for free, so I came home now why is this happening?? in the winter this happened but went off a few weeks later.man these problems are very expensive just cant afford repairs. Rick
