[4th Gen : 01-07]: 03 Caravan, P0442 and P0455
Old Jul 11, 2014 | 08:49 AM
GRNDPNDR's Avatar
GRNDPNDR
Default 03 Caravan, P0442 and P0455
I got a great deal on a Caravan but it has a P0442 and a P0455 code for the evap system.
Anyone have experience with those codes and know how to fix it or what might be causing it?
Old Jul 13, 2014 | 09:27 AM
GRNDPNDR's Avatar
GRNDPNDR
I guess I'll just have to check the lines from what I've been reading.
I only posted this thread in hopes it would be similar to my old car which was ALWAYS a solenoid whenever one of them threw an evap code and that someone might know.....
In this case however, it's apparently just a leak and not something so straight forward.
Old Jul 13, 2014 | 01:53 PM
Cougar41's Avatar
Cougar41
This will at least give you some areas to inspec. Cracked hoses under the air cleaner box are a common complaint:
Old Jul 13, 2014 | 02:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
Check the LDP pump hoses and the small Evap hose under the air cleaner box. If those are good, then replace the Evap vent valve. And maybe try a known good gas cap.
Old Jun 17, 2016 | 10:38 PM
GRNDPNDR's Avatar
GRNDPNDR
Thanks guys, I know it's been a long time but I'm now looking at trying to fix this as I have to get my van etested.
I just replaced the O2 sensor as I had a code for that and now have a P0442, P0455 and P0456
So I'll check out the hoses under the filter box and other areas that I can inspect.
Old Jun 18, 2016 | 04:00 PM
GRNDPNDR's Avatar
GRNDPNDR
I check under the airbox and found the short piece of hose that connects the test port to the solenoid to be completely rotted, the rest seemed ok.
I haven't looked under the van yet but this was likely the source of the large leak.
Old Jun 19, 2016 | 01:35 PM
offgas's Avatar
offgas
Do you know Redneck Rickem? (of YouTube fame?)? Just curious.
Old Jun 20, 2016 | 10:00 AM
GRNDPNDR's Avatar
GRNDPNDR
I do not, why do you ask?
I may have seen one or two of his videos.... maybe.
Old Jun 20, 2016 | 10:06 AM
GRNDPNDR's Avatar
GRNDPNDR
oh and replacing the small piece of hose may have done the trick to solve all my vacuum related codes.
It's been a few days and while I haven't done much driving it has been through a few complete start cycles and so far no MIL..... yet.
Old Jun 20, 2016 | 11:36 AM
offgas's Avatar
offgas
Because my understanding is that he is from London, Ontario. I might be wrong. I was just curious.
I'm glad your problem was solved. Thanks for reporting what you found.
