[3rd Gen : 96-00]: fail emissions
even on a 1998? wow really on a 4.0l? would there be signs? I seem to notice that the intake on mine when I pulled the throttle body to clean so signs of heavy film of oil in it. oppsosite to the throttle body by the battery side I notice that the plastic seam off the intake shows bit oil like if its cracked maybe?
mastertech whats the firing of the cylinders of the 1998? this is a mitubishi engine right? http://www.justanswer.com/uploads/am...59_3_liter.gif
if they wired the first 3 in front could it possible give out this code?
If it's a 3.0 then yes its a Mitsu 6g72.
Code 302 is a cylinder 2 misfire. I would check your wires and make sure everything is where it should be. Also check for vacuum leaks as they can cause a ton of issues.
