[5th Gen : 08+]: 2010 grand caravan 4.0l oil
Old Oct 4, 2014 | 10:03 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
Default 2010 grand caravan 4.0l oil
ok I did oil change like 2500km ago. today did normal check and I found the oil at min. I added like estimate 1/2 quart to get it to the middle of the max and min. I found this happen once before. although all others been dead on the time of change where I filled it before, everything seems dry that I can see. I think I will change it once more now and see or maybe just monitor the amount see. but find its weird It lost.
Old Oct 5, 2014 | 04:45 AM
ice445's Avatar
ice445
Any white smoke out the tailpipe on a cold start?
Old Oct 5, 2014 | 09:23 AM
DodgeCaravan2010SXT
nope no white smoke.
Old Oct 5, 2014 | 09:58 AM
ice445's Avatar
ice445
Is the coolant return jug dirty and oily inside? How does the coolant look?
Old Oct 5, 2014 | 10:33 AM
DodgeCaravan2010SXT
coolant is clean red. little lower than the max I ussualy leave it at but no leaks and I know over time the coolant does evap a bit. but taling like 1/8 to 1/4 down here.
this is strange due to me not seeing visual leak of sorts but its possible burning a bit due to the aspect I don't drive this vehicle that offen and when we do short distances in the area which is not the best of worlds.
Old Oct 5, 2014 | 12:43 PM
ice445's Avatar
ice445
Check the oil pan and underside of the engine in general for any unusual amounts of oil. Otherwise, you're probably burning it. Which is a can of worms in itself. Piston rings, valve guides, or something as simple as a stuck PCV valve can be where you're losing it at.
Old Oct 9, 2014 | 04:00 PM
1wraith's Avatar
1wraith
What about driving habits? I don't drive my van hard so the oil level has always been dead on when coming up on changes. With a Honda I used to own if I drove it hard, I'd add a quart in between changes. If I drove it nice, no need to add oil.
Old Oct 9, 2014 | 05:29 PM
DodgeCaravan2010SXT
not hitting it hard at all. normal driving. although lately seems that I have at times needed to merge to hit gas a rev do hit as high as 4k then change gears.
I added about a quart and see in a few more km to verify level. wise I just do another oil change and re monitor.
