[General]: 4.0 injector swap
Old Jan 1, 2015 | 07:46 PM
DuallyAgain's Avatar
DuallyAgain
Default 4.0 injector swap
Hello all,
I'm working on a 2007 Pacifica 4.0 . I'm told that it's the same engine in mini vans. If this is true, does anyone have the procedure for replacement of fuel injectors?
Or can someone suggest where to look?
Thanks
Old Jan 1, 2015 | 11:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
Yes it is. The upper intake would need to be removed and then remove the fuel rail bolts and lift the injector from the intake manifold. Be careful with the O-ring on the bottom of the injectors.
Old Jan 2, 2015 | 06:45 AM
DuallyAgain
GREAT !
Thank you.
