[5th Gen : 08+]: Door lock wiring
Old Jan 10, 2015 | 11:04 PM
cbacheson's Avatar
cbacheson
Default Door lock wiring
Hello: I'm installing an Accele RS505 wireless keypad on my '08 GC. The install guide has wiring diagrams for Positive Trigger 12V, Negative Trigger 12V, and "Motor Driving". From other searches, I think the van is negative trigger, but how do I confirm that? There are violet w/green stripe and green w/white (or yellow) stripe wires coming from the driver side door switches for the lock and unlock. Can/should I splice into these? From other searches on this site, and Modified Life, I think I need to use a 5.3k ohm 1% resistor for the lock, and a 2k ohm 1% resistor for the unlock. If I'm correct, does that mean just insert the resistor between the wire from the keypad controller and the door lock/unlock wires? Is there a specific wattage resistor I should use? Thank you to any and all who have any knowledge of this wiring.
Old Jan 13, 2015 | 04:48 PM
Cougar41's Avatar
Cougar41
Not a clue on the rest but if you need a wire diagram send me your email address via a private message. How? Click Cougar41 at left.
Old Jan 17, 2015 | 01:21 AM
cbacheson's Avatar
cbacheson
Thanks for the offer. Do you know how to determine if the locks are positive or negative trigger?
