[4th Gen : 01-07]: 2006 Grand Caravan 3.8
Old Jun 28, 2015 | 03:20 PM
Ole Goat's Avatar
Ole Goat
Default 2006 Grand Caravan 3.8
I just saw the Engine Light come on checked the Code P0456-EVAP SYSTEM SMALL LEAK . My question is how critical is this, & should it be attended to ASAP, or can it be driven for a few more days?
Old Jun 28, 2015 | 04:22 PM
Cougar41's Avatar
Cougar41
Gas cap tight? Drive it for years. The EVAP system traps gas fumes in a charcoal canister while the engine is off. If you have an emissions test coming up you'll have to fix it.
http://www.obd-codes.com/p0456
This shows the most common leak areas:
Old Jun 28, 2015 | 06:25 PM
Ole Goat's Avatar
Ole Goat
Cougar41
Thank you for the quick reply.
Old Jun 30, 2015 | 11:26 AM
Ole Goat's Avatar
Ole Goat
Smile 2006 Caravan 3.8 Code P0456-EVAP SYSTEM SMALL LEAK
Got the leak fixed within 5 minutes. Problem was a small amount of rust on the filler neck, took some sand paper cleaned it off, the rubber grommet on the cap was still pliable. Sprayed a little grease on the filler neck, problem solved.
Old Jun 30, 2015 | 04:14 PM
tjnc's Avatar
tjnc
listed from common to uncommon:
  • crack in one of the many hoses
  • filler neck or filler cap(despite what internet says gas caps from parts houses work great I use the ones with the lock for $16 instead of getting the Mopar ones(Mopar has a locking gas cap too))
  • valve under radiator support by right headlight
  • charcoal box below drivers
That's all. This can actually be a headache to fix if it's one of the expensive boxes or multiple cracked hoses. Smoke machines are expensive and a lot of shops don't have them so they trial and error at your expense..
