[4th Gen : 01-07]: Transmission grinding noise
Old Oct 28, 2015 | 12:59 PM
georgi's Avatar
georgi
Default Transmission grinding noise
2001 Dodge Caravan 2.4L
The transmission was rebuilt. Soon after it I noticed grinding sound when accelerating between 45-55 mi/h. Went back to the shop but during the drive test there was no noise. I found the sound is weak and can be heard when the road is smooth and there are no noise from the traffic around.
I made a record of the noise. Any suggestion is appreciated.
Old Nov 1, 2015 | 01:05 AM
master tech's Avatar
master tech
Site Moderator & Tech
It is a bearing type of sound. Was it there before the repairs? Does the sound change when you turn the steering wheel left or right? I would raise the vehicle and try isolate the sound on the lift.
Old Nov 3, 2015 | 07:35 PM
georgi's Avatar
georgi
This sound came after transmission was rebuilt. It is not connected with the turning of the steering wheel.
Old Nov 13, 2015 | 12:22 AM
master tech
Is the transmission a 3 speed which I'm guessing or a 4 speed. But it sounds like a transfer gear bearing.
