[3rd Gen : 96-00]: '98 GCvan Erratic Downshift and Then Limps
Old Nov 28, 2015 | 10:15 PM
AKSport's Avatar
AKSport
Unhappy '98 GCvan Erratic Downshift and Then Limps
'98 GCvan, 3.3l, 4-speed auto, about 110,000 mi. Service Engine light on and Climate Control lights flash. Tranny shifts up and down gears smoothly. After a few minutes driving, when slowing for a turn and then accelerating after turn, tranny downshifts harshly briefly then settles in a more appropriate gear and shifts normally. After a couple or three of these sequences the tranny jumps into Limp Mode. Have found that if I go to Neutral and coast, turn off engine, re-crank engine, and go back to Drive the tranny resets and shifts normally and the sequence starts again. Have noticed that if I get to highway speeds, its fine until traffic slows and then Limp Mode. Replaced the shift solenoid to no effect. Fluid and filter, of course. Any ideas other than tranny replacement? Thnx
Old Nov 28, 2015 | 10:20 PM
What is the code from the check engine light?
Old Nov 28, 2015 | 10:29 PM
AKSport's Avatar
AKSport
Doing this on my own. Don't have a code reader.
Old Nov 28, 2015 | 11:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
I need you have the vehicle scan for codes. I can guess at your problem, but that's all it is. I am a dodge transmission tech. So I need to know the codes.
Old Nov 28, 2015 | 11:47 PM
Either take it to an auto parts store to have them scan for you, or spend $20 and buy yourself a code reader. Can't help without knowing the code.
Old Nov 29, 2015 | 12:27 AM
AKSport's Avatar
AKSport
Thnx. I'll get the codes.
Old Dec 2, 2015 | 07:28 AM
smokesxt's Avatar
smokesxt
This should be obvious but, HAVE YOU CHECKED THE FLUID?
If our van is as little as 1/2qt low, it will act up like this. If you haven't checked it, do that first.
