[4th Gen : 01-07]: No start or spark
Old Dec 15, 2015 | 05:20 PM
caravan2003's Avatar
caravan2003
Default No start or spark
I have a 2003 dodge caravan with a 3.3. I pulled the motor and put a crank kit and new timing chain. After putting the motor back in, it won't start. I removed one plug and only fires when not cranking.
Old Dec 15, 2015 | 07:21 PM
caravan2003
Any thoughts where to start to check?
Old Dec 15, 2015 | 07:33 PM
caravan2003
I'm thinking crank sensor, does anyone know if the flywheel has a bolt pattern or does it go in any pattern
Old Dec 16, 2015 | 04:14 PM
caravan2003
Any comments or suggestions would be appreciated, or just let me know someone is out there!
Old Dec 17, 2015 | 07:22 AM
caravan2003
Ok, since no one will reply or help I guess I'll have to figure it out on my own! Thank's for all the help and replies!
Old Dec 18, 2015 | 07:08 AM
smokesxt's Avatar
smokesxt
Seeings you pulled the motor to change the chain, I would start by going back through and making sure you have everything plugged in as it should be.
Old Dec 18, 2015 | 12:01 PM
caravan2003
That's what I did first, I'm thinking because the chain and gears were changed I have to pull the cam sensor and put the cardboard spacer on it. Thank you for the reply.
Old Dec 31, 2015 | 08:48 PM
caravan2003
Update! Changed cam sensor and crank sensor, still will not start. Have checked and rechecked all wires and plug ins! Any ideas?
Old Jan 1, 2016 | 06:19 PM
caravan2003
Got a coil pack today, checked all wires and connections. Checked fuses, and plug ins under the fuses cleaned all connections. Still no start SOMEONE PLEASE HELP!
Old Jan 2, 2016 | 07:17 AM
smokesxt's Avatar
smokesxt
Hate to ask it:
Are you 100% sure you have the timing set correctly?
