[4th Gen : 01-07]: what did you finally do when p0420 code came?
06 caravan, 88000 miles. engine light drew a p0420 code after changing my radiator two days earlier myself. the engine never got hot, nor really low on coolant. I caught it early.
does that code necessarily mean the rear 02 sensor, or front sensor if i chose to replace one of the two sensors as a means to correct issue. the engine light came on 5 minutes after i went from 30 to 45mph as quick as i could.
i don't want to just change parts but won't pay the cost for a catalytic converter if that comes up. what sensor would you change if you were to change one of the two sensors?
Well almost. I would reset the code first and see if it comes back. They don't sometimes.
http://www.obd-codes.com/p0420
I thank each of you for responding to me quickly. i will pull the negative lead off battery to reset, maybe turn head lights on for 5 minutes to drain any settings. saw that on youtube.
hopefully it will stay off. have only 88,000 miles on it.
from what i read catalytic inefficiency doesn't cause any mechanic issues.
i do know a upstream sensor thats bad causes rick or lean fuel mixture leading to rapidly poor gas mileage.
