[2nd Gen : 91-95]: 94 Dodge caravan 3 litler
Old Mar 27, 2016 | 02:55 PM
stockups's Avatar
stockups
Default 94 Dodge caravan 3 litler
Need some help I have a small transmission leak for the past 4 years. it leaks only when i shut off the engine on the upper right side of the Van. Someone once told me it can be the upper seal. Also I read where the Dodge caravans have problems with the Transmission control Solenoid. One is are they talking about 2 different items and if it is the Solenoid where can it be found. When i check my van it looks like the Transmission control Solenoid is under the battery
plate is that correct. Any help would be great
Sincerely Michael
Old Mar 28, 2016 | 05:27 PM
smokesxt's Avatar
smokesxt
The solenoid is under the battery, on the front of the trans. They have a seal on the bottom, that could potentially be leaking.
I've also had the o-ring for the dipstick leak, which is another place to look.
Old Mar 31, 2016 | 02:19 PM
stockups's Avatar
stockups
where would the o ring be on the dipstick?
Thanks Michael
Old Mar 31, 2016 | 02:30 PM
Thanks Michael
Where it seals with the tube.
Old Apr 1, 2016 | 07:31 AM
smokesxt's Avatar
smokesxt
Thanks Michael
On the bottom of the tube where it goes into the trans, I believe there should be an o-ring. I've had a couple of 604s leak where the dipstick tube goes into the trans.
