[4th Gen : 01-07]: No Spark
Old Apr 6, 2016 | 11:18 PM
Razor89's Avatar
Razor89
Default No Spark
Hello, first post. Need help with a 2006 4cyl Caravan which turns over but doesn't start
Pulled plugs and they are wet. So replaced them. Still no spark.
Swapped coil pack for a new one, no spark. Center pin on the 3 pin electrical connector gets power when you start to crank the motor
I noticed ASD relay is warm. I swapped for another but no change.
My handheld scanner does pickup RPM when engine is spinning over.
I don't have a wiring diagram for the engine, the Chiltons at Advance was totally useless as there is no engine wiring.
TPS works on the scanner. No codes. Engine smells like fuel when cranking over.
Family that owns van has 5 children and trying to help them out. Just not familiar with Dodge.
Thanks to anyone that can help,
Julio
Old Apr 7, 2016 | 12:09 AM
georgef's Avatar
georgef
Originally Posted by Razor89
...I don't have a wiring diagram for the engine, the Chiltons at Advance was totally useless as there is no engine wiring...
BBB Industries provides free access to their database of Technical Service Bulletins (TSB’s) and Wiring Diagrams.
http://www.bbbind.com/tech_database.html
You will need to register to access the information (free).
Old Apr 7, 2016 | 07:53 AM
Razor89's Avatar
Razor89
Thank you for the link. The hunt continues
If the ASD relay clicks when cranking doesn't that indicate cam and crank signals are being seen by the PCM?
Old Apr 7, 2016 | 09:33 AM
offgas's Avatar
offgas
Default Thanks, georgef
Thank You for the link.
Old Apr 7, 2016 | 12:15 PM
cv2003's Avatar
cv2003
You didn't mention anything about the timing belt, so I'll ask if you verified that it's not broken.
