[5th Gen : 08+]: Speedometer failure
Old May 1, 2016 | 07:01 PM
RedCaravan's Avatar
RedCaravan
Default Speedometer failure
Speedometer failed. At first it was jumpy. Stepping down while slowing was most noticeable symptom.
Speed sensor, instrument cluster or something else?
Old May 1, 2016 | 07:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know if you have the 41TE or 62TE transmission? If you have a 41TE I would guess either the sensor or the wire is broken inside the output sensor connector.
Old May 2, 2016 | 08:01 AM
RedCaravan's Avatar
RedCaravan
According to wikipedia the 2008 GC should have a 62TE. Not sure though.
Old May 2, 2016 | 08:20 PM
georgef's Avatar
georgef
If it is the van listed in your "Vehicle Information" (2008 Grand Caravan SXT 3.8) then yes it has the 62TE. Only the vans with the 3.3L had the 41TE.
Old May 3, 2016 | 12:40 AM
master tech
2008 was the last year for the 41TE transmission. Some had a 41TE and some had the 62TE. If you send me the last 8 of you Vin thru a PM. I can you what you have.
Old May 3, 2016 | 12:42 PM
RedCaravan's Avatar
RedCaravan
Its definitely a 62TE. I have a new sensor for that transmission. From what I read there is an input and output sensor. I'm guessing I want to change the output? Thoughts?
Old May 3, 2016 | 06:09 PM
Cougar41's Avatar
Cougar41
Any transmission shift problems? Not at all sure about 5th gen vans but generally if the output speed sensor is toast you will have speedo and shift problems. Both use output sensor data.
Old May 3, 2016 | 07:32 PM
georgef's Avatar
georgef
2010 was the last year the 41TE was used in the Grand Caravans, and always mated to the 3.3L engine (actually the transmission was designated 41TES by then).
The vans with the 3.8L, 4.0L, and 3.6L engines all came with the 62TE transmission.
The image below from page 23 of 2010 Grand Caravan brochure shows that the 4 speed was still available in 2010: 2010_grand_caravan.pdf
Old May 3, 2016 | 08:35 PM
RedCaravan's Avatar
RedCaravan
The problem appears to be somewhat intermittent as the speedometer was functioning but with some jerkiness today. My wife reported an incident that sounded like limp mode but it had never recurred! Could it be PCM gremlins?
Old May 4, 2016 | 11:45 PM
master tech
Is the check engine lamp on? If you do have a 62TE, the input sensor is interchangeable with the output sensor. Remove the output sensor and inspect for debris. Or you have a bad wire connector.
