[5th Gen : 08+]: EGR valve P0404
Old Jun 17, 2016 | 10:12 AM
kuyabribri's Avatar
kuyabribri
Default EGR valve P0404
I'm getting a MIL with P0404 EGR circuit range/performance code. I took the EGR valve out and gave it a good cleaning including soaking the valve end (not the electrical end) in acetone for 20 minutes to try and break up the baked on gunk. After letting it dry out completely I put it back in and on the first drive I heard the warning chime 5-6 times over the course of a mile. Most of the times I heard it there was no visual indication but once or twice I thought I saw "nobus" displayed on the odometer for a brief instant (couldn't really take my eyes off the road for too long). On the next drive cycle the MIL illuminated with the P0404 code but the repeated chiming stopped and I haven't seen "nobus" since the MIL came on. Besides that the only driveability symptoms are occasional rough idle or rarely stalling at idle, both of which get worse on hot days when the air conditioning is on.
I'm now thinking I have an electrical issue with either the EGR valve or its wiring (I've had multiple wiring issues with this van before) and not a mechanical issue with the EGR valve. Is there a way to test whether it's the EGR valve or the wiring so that I don't buy one or the other unnecessarily? I have a couple of voltmeters and a scan tool but otherwise don't have many sophisticated electrical diagnostic tools.
Old Jun 17, 2016 | 09:16 PM
Friar Tuck's Avatar
Friar Tuck
Lightbulb
http://www.obd-codes.com/p0404
Old Jan 23, 2017 | 04:13 PM
jmmorenob's Avatar
jmmorenob
Hi.
I'm still having the same code P0404.
I replaced the EGR Valve, but it's still with the same error when I'm driving for 3 hours in a row. Days after the error, the check engine light it's turn off. I cleaned the EGR tube (4861711AB code from Mopar) too.
Someone knows whats going on?
Thanks in advance, and my apologies for my English!
Best,
jmmorenob
Dodge Grand Caravan 3.3 V6 Flex SE 2008
Old Jan 23, 2017 | 08:39 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
At the end of the intake on passenger side, there are 2 rectangle connectors. One brown and one black. Those are prone to get water in them and corrode like nuts. Unplug them and look for carnage. The repair kits are available, but you can just cut, add wire and splice if you want.
Old Jan 23, 2017 | 08:42 PM
TNtech's Avatar
TNtech
Here's a pic of one I did..........
Old Jan 23, 2017 | 09:41 PM
jmmorenob's Avatar
jmmorenob
Hi TNtech!
Thanks a lot to answer me so fast. Tomorrow I'll check this connection. If this connector it's in bad shape I'll buy a new one and I'm replacing it.
Sincerely,
jmmorenob
Old Jan 24, 2017 | 07:40 PM
georgef's Avatar
georgef
Wow! How common is that?
What years and engines are you seeing this on?
Old Jan 24, 2017 | 10:55 PM
TNtech's Avatar
TNtech
Depends on the environment. Me, many times. I get them dropped off by places who can't fix the related code, most of the time EGR or MAP sensor.
If they get soaked good a couple of times and the water gets trapped, then it slowly starts.
'08, '09 and '10
