[5th Gen : 08+]: 12 V DC Cigarette Lighter not working
Old Aug 4, 2016 | 02:36 PM
Gregory Soave's Avatar
Gregory Soave
Default 12 V DC Cigarette Lighter not working
Hello, I recently purchased a 2012 Dodge Caravan SXT with Super Console inside. There are two 12 Volt DC power supplies in the console, one with the key and the other with the battery. The one with the photo of the key on it work fine, however I can't get the one with a battery image to power my phone charger (tried 2 different ones). I checked the fuses, and they appeared to be fine, and I even switched the 20 AMP fuses with each other to make sure they worked. Is there something else that I am missing? I noticed for the slot it has three different holes for the prongs, but my 20 amp fuse only has two prongs. I was reading that depending on where you put it in, it changes whether it will still work when the car is off.
I just looked inside the socket itself.. I noticed the one working socket appeared to be metal in the back of it, and there was no metal at the back of the non-working socket. Wondering if the socket itself needs to be replaced.
Old Aug 10, 2016 | 01:47 PM
offgas's Avatar
offgas
"I just looked inside the socket itself.. I noticed the one working socket appeared to be metal in the back of it, and there was no metal at the back of the non-working socket"
Do you mean there was no contact in the rear center of the non-working one?
Old Aug 10, 2016 | 01:55 PM
Put a meter on it and see if it has voltage.
Old Aug 10, 2016 | 10:00 PM
Gregory Soave
It was just a piece of plastic stuck in there from the previous owner! It's working now.
