[General]: 3.3l to 3.8l swap
Old Aug 24, 2016 | 04:48 PM
smokesxt's Avatar
smokesxt
Default 3.3l to 3.8l swap
I usually would just mod the 3.3L instead of swapping, but our Voyager just ate it's trans and I can get a low mileage 3.8L van for a steal, so I'm thinking on just dropping the whole driveline in.
Problem, ours is a 95 Voyager, the donor is a 99 GC Sport. Is this going to be a simple swap my sensors to the newer motor, or will I have other things to watch out for as well?
Old Sep 1, 2016 | 07:14 AM
smokesxt's Avatar
smokesxt
Anyone?
Old Sep 6, 2016 | 05:42 AM
BK3's Avatar
BK3
'95 is an OBD1 engine, '99 is an OBD2 engine. So,
there would be a lot of sensors swapped,, ECM swapped, Wiring swapped. There would be much work involved, if it can be done.
Old Sep 7, 2016 | 07:02 AM
smokesxt's Avatar
smokesxt
So I've been playing with this the last couple days. The trans computer interchanges, as I was able to plug a 93 TCM into the 99 van and everything worked as it should. As far as engine, I intend on swapping my 3.3L's sensors to the 3.8L and running it off my ECM.
Old Oct 7, 2016 | 07:32 AM
smokesxt's Avatar
smokesxt
Got into tearing it down. The 99 3.8L ran an extra trans mount that my van doesn't have, so I ditched it and picked up one of the correct year to swap the trans.
