2005 Dodge Caravan P0032, loose gas cap?
Old Dec 31, 2016 | 01:23 PM
JudiG's Avatar
JudiG
Default 2005 Dodge Caravan P0032, loose gas cap?
I had the engine light come on a week ago with the P0032 code. I parked it and borrowed someone's car to get to work. A coworker suggested it could be as simple as a loose gascap. I checked today, and sure enough, the last time I went for gas, the gasjockey hadn't screwed it back in all the way. So I reseated the cap today. How long will it take for me to know i that's the problem? The engine light is still on.
Old Dec 31, 2016 | 06:26 PM
Daves69's Avatar
Daves69
JudiG, so you know you've posted in the wrong forum.
caravan forum link......
https://dodgeforum.com/forum/dodge-caravan-23/
Are you sure that P0032 is the code you have?
A P0032 DTC trouble code may be caused by one or more of the following:
A short in the heater circuit in the sensor
A failed O2 sensor heater
Wiring/connectors broken/frayed leading to sensor and/or relay
Failed PCM/ECM
code link...........
https://dodgeforum.com/forum/dodge-c...codes-mil.html
Old Dec 31, 2016 | 09:38 PM
lxman1's Avatar
lxman1
Site Moderator
Moved to the correct forum.
