[5th Gen : 08+]: Need full wiring Wheelchair van ...diagram and suggestions 2012 grand caravan
Old May 15, 2018 | 04:48 PM
xtal_01's Avatar
xtal_01
Default Need full wiring Wheelchair van ...diagram and suggestions 2012 grand caravan
Hey!
OK, tried the dealer and another mechanic first ... no luck.
Background, my wife has a special handicapped equipped 2012 grand caravan. Time for inspection but the air bag light it on. I went to the dealer, they said since the van had been modified, they will not even look at it.
They did say it was an airbag sqib 1 and 2 are showing open, passenger seats occupant detector high (with no one in the seat) and seat belt open when it is locked in place.
I then tried a local dealer that claims to fix wheelchair vans ... again no luck.
The problem is a third party company out of the mid west (about 800 miles away), cut the floor out of the van and dropped it 9". to do this they removed and extended a lot of the wires.
The van was then shipped to the east coast and some more modifications done (like the seat belt moved and a wheelchair lock plate added) by another company (they are a days drive away).
We live in Vermont.
So, I am guessing I have a wiring problem since all these things just came up at the same time.
Non of the companies that worked on the van will help me with a wiring diagram ... although it seems like all they did was extend and move existing wires.
I am good with a meter and tracing connections if I have a diagram.
Can anyone help me locate one for this van?
Also, any suggestions on where I should start looking? There is no longer a drivers seat. The wheelchair just locks into a plate there.
Traction light has been acting up ... so I need to look at the clock spring?
Oh, and also, suggestions on a decent (but not tooooo expensive) code reader? I got a cheap reader that feeds into a tablet ... uses free software .... no giving me any error codes.
Any advice would be greatly appreciated!!!!!!!!
Mike
Old May 15, 2018 | 05:33 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Dealer has NO ACCESS to this and they do not sell them from factory this way.
I can tell you though that most of them I look at are different from the next one. There really is no set template for these retrofits. Possibly a motor home center could be of assistance.
If you have no experience with airbags, then I wouldn't go poking around.
Old May 15, 2018 | 06:47 PM
xtal_01's Avatar
xtal_01
I am sure it is not the airbag or seat or seat belt switch. All would not fail at the same time. My best guess it a connector corroded or was damaged or the wiring harness damaged.
If I have a wiring diagram, I can trace out each wire and see where the problem is.
Thanks ... Mike
