[4th Gen : 01-07]: 02 Grand Caravan skip
Old Jun 19, 2018 | 02:40 PM
Jettastr4's Avatar
Jettastr4
Smile 02 Grand Caravan skip
my 02 Grand Caravan 3.8 L (84,000 mi) skips on startup for a few seconds and then clears out, it has a cylinder 03 Misfire code in it for the check engine light.
Also the gas mileage is TERRIBLE- 10 mpg or so.
Any insight on this? I figure it may need plugs but the skip clears out so I was thinking a leaking down injector?
ANYTHING that will help the mileage I am getting, its expensive to feed this thing with that type of mileage. Has new fuel pump and filter on it.
its a handicap conversion if that matters.
also which cylinder is #3 I am used to german cars...
Old Jun 19, 2018 | 02:55 PM
For starters, fix whatever is causing the misfire code.
Old Jul 5, 2018 | 02:31 PM
Jettastr4's Avatar
Jettastr4
That's what I'm trying to figure out isn't it.
Putting new plugs in it, got the REl4PLP5's, we'll see what that does.
Old Jul 8, 2018 | 09:00 PM
rhensonsr's Avatar
rhensonsr
Replace wires as well. Also check for a sp wire off.
Old Jul 9, 2018 | 05:05 PM
Jettastr4's Avatar
Jettastr4
well the plugs didn't fix it, as the skip has returned. The wires all are installed correctly, so we have swapped the 3 and 4 cylinder wire to see if the problem follows, if it does we know its a wire issue.
