[5th Gen : 08+]: 2010 Dodge caravan No power at obd2 port
Old Oct 24, 2018 | 11:44 PM
Sousmon's Avatar
Sousmon
Default 2010 Dodge caravan No power at obd2 port
I have a 2010 dodge caravan 3.6L I have no power at the obd2, I plugged in multiple different scanners and none of them can connect.
Old Oct 25, 2018 | 09:05 AM
Checked the fuses?
Old Oct 25, 2018 | 02:16 PM
Sousmon's Avatar
Sousmon
I checked all fuses under hood
Old Oct 25, 2018 | 03:59 PM
Any interior fuse box?
Old Oct 25, 2018 | 08:59 PM
georgef's Avatar
georgef
Double check the M30 fuse, it is a 15 Amp Blue fuse for the Rear Wiper Module, Power Folding Mirror, and J1962 Diagnostic Feed (OBD2 port).
Did you actually test for power on pin 16 of the OBD2 port?
Old Oct 25, 2018 | 11:50 PM
Sousmon's Avatar
Sousmon
I didn’t test actually power at the port, would you be able to help me out with pin 16, also i didn’t find a interior fuse box and when I looked on google I couldn’t find a interior fuse box
Old Oct 26, 2018 | 08:10 AM
GumbyRT's Avatar
GumbyRT
I can't look at vehicle specifics right now, but in most cases, the battery positive feed for the OBD2 connector is on the same fuse as the power ports (or, as they used to be known, cigarette lighters).
Check your owners manual for location on interior fuse panel - sometimes they're hidden in funny places.
Old Oct 26, 2018 | 10:10 PM
georgef's Avatar
georgef
Originally Posted by Sousmon
I didn’t test actually power at the port, would you be able to help me out with pin 16...
From http://www.obdii.com/connector.html:
...also i didn’t find a interior fuse box and when I looked on google I couldn’t find a interior fuse box
There is not an interior fuse box, did you double check fuse M30?
Old Oct 27, 2018 | 08:41 AM
GumbyRT's Avatar
GumbyRT
I didn't read this closely enough the first time - which one do you mean:
1) The scanner will not power on.
2) The scanner will power on but will not read codes.
If it's the second, it's a separate issue from power supply. You'd want to be looking at the data circuit between the OBD2 port and the PCM.
Old Oct 28, 2018 | 05:31 PM
Sousmon's Avatar
Sousmon
the scanner will not power on
