[4th Gen : 01-07]: 20072007 Grand caravan sliding power door problem
HelloI am having a problem with my passenger’s side sliding door. It will not open and close consistently.
Most of the time you will hear the motor trying to work but the door will not move. This is true from the key fob and also the buttons inside the van. It is more likely to work opening the door than closing. The lock works fine and it does open/close on occasion so I do not think it is a motor issue. I am thinking maybe there is a bad connection somewhere that just catches sometimes. Does anyone have any thoughts on what I can check or tests I can run?
Thanks
hjski
Thanks
hjski
